1 - 5 of 5 Posts
I just changed the fan clutch and thermastat and while I had the air duct off and out of the way I looked in the entrance of the throtle body at the throtle flap and it was a little gummy in the area so I sprayed the area with carb and choke cleaner the cleaned with a toothbrush and wiped cleaned, put everything back togather and now the idle want idle down, I took the duct back off and re-cleaned and sprayed in the area made sure all the duct work is hooked up and the problem still exsist. Help!
Thanks
1 - 5 of 5 Posts
