1 - 6 of 6 Posts
I have a 5/2007 Highlander Limited 3.3L, with 140K. I am an auto tech for another brand. Are there any Toyota dealership techs that can list the idle relearn steps for a throttle body like mine without an idle valve?
I have been chasing mixture too lean fault(s) on bank 2. I disconnected the battery today to clean two chassis ground points one below the engine junction box in the left front fender/nose area and the other under the battery, and now she won't idle worth a damn, stalls too. Fuel pressure is 50psi with good volume. o2 sensors are ok and the exhaust has no leaks. Mass air flow meter is a brand new original Toyota part.
Thanks in advance
2016 Corolla S Prem
Some Toyota engines are worse than others. Wife's '04 Rav would stall, my '08 Tacoma was just a bit rough.
An hour or so of driving and a couple of restarts will be all it takes... it's pretty quick.
I don't think there's any way to force it.
Every time I disconnect my battery it takes about a trip to my job before it starts acting normal. It’s about 8 miles or roughly 45-60minutes street driving. Generally I throw the car in neutral if I feel it’s going to shutoff while idling at a light during the drive. Good Luck
Kluger/Highlander
Happened a couple times to me when I forgot to reconnect MAF or the TB harness when I was cleaning the Tb and another stuff under there.
Are there any CEL or VSC TRAC OFF lights? if there are check the codes or check pending as mine always threw a code when I forgot to reconnect one of them. or Perhaps check the air filter box is sealed as on mine the back right - firewall side is a PITA to get back in place and will idle like crap if the box isn't firmly sealed
I've found just letting it idle for a few minutes after reconnecting it should settle down after about 5 mins or as the temp comes up. The take it for a drive round the block If it doesn't play ball then I disconnect battery and try again. Usually works second time for me. It usually Idles very high and drops down
Chasing lean codes for me was a filthy MAF - didn't have idle issues though just poor throttle response. Could the MAF be faulty or the connection not tight into the intake or electrical? My MAF screws points are stripped and I use a larger threaded screw to keep it in place although my rubber seal around the base of the MAf is super tight so it kinda stays in place without needing the fasteners and I sure as heck use them as I don't want the bugger coming loose or falling out.
The ECM has very limited 2 way tests or the like as far as I'm aware. A good professional Scan tool or the techstream software should have access if the option is there.
What are your fuel trim numbers? Do you have access to Mitchel or alldata? I'm at home now and don't.
Sent from my Moto E (4) Plus using Tapatalk
1 - 6 of 6 Posts
