Hi everyone.
My RAV is a 95 model with a 3SFE engine. The throttle body is the 4 bolt model with single vacuum from the fuel fume canister. It's the one with the EGR mounted somewhere below and behind the engine. It is NOT the one with the EGR mounted on the manifold.
My question is where dose the Idle Control Valve get it's air from?
The book does not say. However the book shows a diagram with the supply hose going into the air intake filter cover. The only thing going into my filter cover is the air temp sensor.
The idle valve hose goes straight down and under the engine. Despite my best efforts, I cannot find where it actually goes to. It must be filtered at the other end and I want to check - clean -replace that filter.
Thanks for your help
