my 91 had a similar problem, check that the throttle cable isn't caught on anything. The cylinder thing that attatches it to the throttle body was out of place in mine, and the throttle body was stuck open a little bit. Adding a little more tension to the cable should fix it if you have the same problem I had. My idle usually drops a little bit when I let the clutch out as well, don't know why though.
