I had a friend send me the following. Does this sound correct? Has anyone tried this on an 06 or 07 Tacoma?
The second programming option allows you to set the doors to lock when the key is turned on, and unlock when the key is turned off.
- Open the driver's door. Remove the key from the ignition switch.
- (Complete these steps within 30 seconds)
- Insert the key into the ignition switch.
- Close, then open the driver's door 2 times.
(SHUT - OPEN - SHUT - OPEN) - Turn the key from LOCK to ON 5 times, ending at ON
(LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON)
- Programming option (select one of the following).
- [Ignition controlled lock ON] Close the driver's door.
- [Ignition controlled lock OFF] Close the driver's door twice, leaving it closed.
(SHUT - OPEN - SHUT)
- Turn the key to LOCK. The programming is complete. If programming did not occur, start over
