WOW
I went to Jasper Engines & Transmissions at 1-800-827-7455.
And got a Quote!
Updates:
GRAPHITE COATED PISTONS:Graphite is a natural lubricant which helps
prevent dry start up and piston scuffing.
MOLY PISTON RINGS:Higher durability, reduce cyl. wall wear.
GRAPHITE HEAD GASKETS
liable material that does not tear when casting
expand and contract. Graphite gaskets transfer heat evenly and will
not deteriorate around water passages like Kevlar gaskets do.
VITON VALVE STEM SEALS:This material meters oil from the first running
of engine. Its design is resisant to heat, oil additives and abrasion.
OEM PARTS INSTALLED
Product summary: With Water Pump
Block casting: 3VZFE
W/O TIMING COVER
CAN INTERCHANGE WITH 478310
CORE ID=3VZFE LARGE 2" RIBBED LETTERS ON THE BLOCK
Core Policies:
For full details of the Core Policies, click here, or call Jasper
Pricing and Availability:
The Price Is: $4574.00
Core Deposit For This Unit Is: $500.00
Skid Deposit For This Unit Is: $15.00
Sold On An Exchange Basis w/Jasper Receiving Old Unit As A Core.
Additional Information:
Read more about our remanufactured gasoline engines
To ensure proper installation of gas engines, JASPER sells an
Installation Kit. Please call 1-800-827-7455 to be sure we have your
correct application.
