So yesterday I was driving on the highway and suddenly my car started jerking and misfiring. I plugged in my code reader and had a misfire on cylinder 4. I was limping the car home and about ten minutes later my car was running fine again. It's a 1ZZ-FE engine with 245,000 KM on it. It's had a new intake manifold gasket and plugs (Denso - High end) done about 5K ago and was running fine until today. I took it for a small drive again later and it didn't give me any trouble. I now don't feel confident driving but can't find the problem either. The check engine light was flashing on and off randomly but never stayed on in the end. I swapped the coil pack on cylinders 3 and 4 to see if the problem happens again in cylinder 3 then I know it's the coil pack.
Since the plugs were done 5K ago I am trying to determine the intermittent cause of this. Coil Pack? Injector?
Should I just get a coil pack and drive around with a 10mm socket and do a swap if it acts up? I can get a Denso coil pack for 100CDN or a set of 4 Spectra Premium coils for about the same price and just replace them all. I just figured a coil pack would either work or not but electrical can be a fickle mistress too.
Codes I pulled:
P0304 - Misfire cylinder 4
P0456 - Small EVAP leak detected
Codes I pulled:
