1 - 12 of 12 Posts
G
Three months ago I purchased a 2001 Corolla with 80k on it. I have now
discovered that it burns oil to the tune of 1 quart per 200 miles.
Please consider the following facts: The car runs great. It has no oil
splatter anywhere underneath or under the hood. The parking spot is
completely free of any drippings. There is absolutely no blue exhaust
even on initial startup. Compression tests on the cylinders revealed
200 psi per cylinder (book says 145 min. 218 max.). The spark plugs
did have white ash on them but were dry and not eroded. This is mind
blowing, where is all that oil going??? 8O
Posted at author's request, using http://www.AutoBoardz.com interface
Articles individually verified to usenet standards. Visit URL to contact author/report abuse
Thread archive: http://www.AutoBoardz.com/disappearing-oil-mystery-2001-Corolla-Toyota-ftopict201970.html
G
Discussion Starter · #2 ·
> discovered that it burns oil to the tune of 1 quart per 200 miles. Please
> consider the following facts: The car runs great. It has no oil splatter
> anywhere underneath or under the hood. The parking spot is completely free
> of any drippings. There is absolutely no blue exhaust even on initial
> startup. Compression tests on the cylinders revealed 200 psi per cylinder
> (book says 145 min. 218 max.). The spark plugs did have white ash on them
> but were dry and not eroded. This is mind blowing, where is all that oil
> going??? 8O
Look around the oil pan. As I have said here before, I had two Corollas
that suffered from the oil pan loosening. Same thing: no oil-fouled plugs,
no dripping, no blue smoke, etc, but a thick sludge around the oil pan.
It only 'escapes' when there is enough pressure to force it past the
seals. So, when you're driving on the highway, you're probably leaving a
trail (ever so slight) of oil behind you...
G
Discussion Starter · #3 ·
PCV valve?
G
Discussion Starter · #4 ·
PCV valve is fine. I will check for a sneaky oil pan leak. Keep the
ideas coming folks - I appreciate them all.
> have now discovered that it burns oil to the tune of 1 quart
> per 200 miles. Please consider the following facts: The car
> runs great. It has no oil splatter anywhere underneath or
> under the hood. The parking spot is completely free of any
> is mind blowing, where is all that oil going??? 8O
G
Discussion Starter · #5 ·
I can't imagine how a quart could disappear in only 200 miles and you can't
see it coming out form somewhere -- either on the ground or out the tail
pipe.
The key to compression testing is that all cylinders be the same -- within
about 10% of each other. If you have that, then you have good rings.
"Artesia" <[email protected]> wrote in message
news:[email protected]
> author/report abuse
> Thread archive:
G
Discussion Starter · #6 ·
"Jeff Strickland" <[email protected]> wrote in message
>pipe.
I was waiting to see if anyone provided a good clue, and Hachiroku seems to
be the closest. Based on the condition of the spark plugs, compression test
results, and lack of blue smoke, I'd guess that the oil is leaking out
somewhere or getting into the coolant. Check the condition of the oil to
make sure it does not have a milkshake appearance and make sure that there
is no oil mixed with the coolant.
Look for leaks around the oil pan, valve cover gasket, head gasket, oil
filter, and crankshaft seals.
Ray O
>> author/report abuse
>> Thread archive:
G
Discussion Starter · #7 ·
>>can't see it coming out form somewhere -- either on the ground or out the
>>tail pipe.
>> within about 10% of each other. If you have that, then you have good
>> rings.
> to be the closest. Based on the condition of the spark plugs, compression
> test results, and lack of blue smoke, I'd guess that the oil is leaking
> out somewhere or getting into the coolant. Check the condition of the oil
> to make sure it does not have a milkshake appearance and make sure that
> there is no oil mixed with the coolant.
The Supra had a loose pan, too. But that's not all. A leaky valve cover
gasket makes itself quite apparent...if you have a sense of smell!
The valve cover gasket is leaking SO bad that after a run from Deerfield
to Brattlebor you could see the smoke coming out from under the hood! It
was a lot worse before I tightend the nuts (of course I went cross-cross!)
but it still is visible if you're looking...or after you get a good whiff!
That will be a project for next week or the week after...along with new
plugs and wires. The wires are corroding from the oil!
G
Discussion Starter · #8 ·
news:[email protected]:
> miles and you can't see it coming out form somewhere --
> either on the ground or out the tail pipe.
> same -- within about 10% of each other. If you have that,
Beg to differ with you but good compression does not always
equal good oil control. You can have stuck oil control rings w\
fully operational compression rings & therefore burn oil. Each
piston has oil control rings & separate compression rings.
dc
G
Discussion Starter · #9 ·
Re: Re: Incredible disappearing oil mystery - 2001 Corolla
I also can’t imagine where 1 quart of oil would go in 200 miles and
not be able to see it. This is what drove me to make a post for the
first time in my life. Once again, all four cylinders tested out at
200 psi on the nose with proper needle climb. The best guess I’ve read
so far is the idea of a leak that only presents itself when the
crankcase pressure is up. I really need to go over this closer to look
for clues. There certainly are no obvious ones. I have excellent
eyesight and sense of smell, no blue smoke or odor. Thanks for the
time you take to reply.
> miles and you
> ground or out the
> >>tail pipe.
> same --
> have good
> >> rings.
> Hachiroku seems
> plugs, compression
> is leaking
> make sure that
> gasket, oil
> valve cover
> smell!
> Deerfield
> the hood! It
> cross-cross!)
> good whiff!
> with new
G
Discussion Starter · #10 ·
A quart every 200 miles (3-4 hours at speed) isn't exactly a "stream"
of oil, maybe only a drop every few seconds. My recommendation is to
warm up the car, run it while stationary at 2000 RPM or so for a minute
or two over a clean area or piece of newspaper, and see if any new oil
can be spotted leaking from the pan or somewhere else.
> pipe.
> > author/report abuse
> > Thread archive:
G
Discussion Starter · #11 ·
Allow me to ask the stupid question, how do you know it lost a quart? Has it
lost a quart more than once, or did you have the oil changed, then check the
oil after 200 miles and found some missing?
>I also can't imagine where 1 quart of oil would go in 200 miles and
> 200 psi on the nose with proper needle climb. The best guess I've read
> > miles and you
> > ground or out the
> > >>tail pipe.
> > same --
> > have good
> > >> rings.
> > Hachiroku seems
> > plugs, compression
> > is leaking
> > make sure that
> > gasket, oil
> > valve cover
> > smell!
> > Deerfield
> > the hood! It
> > cross-cross!)
> > good whiff!
> > with new
> author/report abuse
> Thread archive:
G
Discussion Starter · #12 ·
On Mon, 01 Jan 2007 19:25:24 +0000, Artesia wrote:
> I also can’t imagine where 1 quart of oil would go in 200 miles and not
> be able to see it. This is what drove me to make a post for the first time
> in my life. Once again, all four cylinders tested out at 200 psi on the
> nose with proper needle climb. The best guess I’ve read so far is the
> idea of a leak that only presents itself when the crankcase pressure is
> up. I really need to go over this closer to look for clues. There
> certainly are no obvious ones. I have excellent eyesight and sense of
> smell, no blue smoke or odor. Thanks for the time you take to reply.
You're welcome. It's a weird problem. On one car, the sub-frame under the
engine was showing oil, but on the other, there were no signs except for a
low dipstick! But, I caught it early, having had it happen on the car I
owned right before it!
If it goes on for a while, you should see oil SOMEWHERE, on the floor pan,
the rear axle, somewhere! Have you gotten down on all fours and had a good
look underneath?
> > miles and you
> > ground or out the
> > >>tail pipe.
> > same --
> > have good
> > >> rings.
> > Hachiroku seems
> > plugs, compression
> > is leaking
> > make sure that
> > gasket, oil
> > Deerfield
> > It
> > cross-cross!)
> > whiff!
1 - 12 of 12 Posts
