281 - 300 of 308 Posts
TN の がしょう
2015 Camry XSE V6
Discussion Starter #281
Updated the first page with the addition of an Electrical Throttle Response Controller.
TN の がしょう
2015 Camry XSE V6
Discussion Starter #282
Banned
Updated the suspensions page.
Included TEINS newest offering of coilovers for the 2015-2017.
Street Advance Z is the newest coilovers that not only is it one of the cheapest offered, it's also of high quality you can get since it's TEIN.
http://www.tein.com/srch/us_search.php?maker=TOYOTA&carmodel=&modelyear=&item=STREETADVANCEZ
i see no top plates come with those. i would like to see some reviews, i want to put lowering springs on but i dont want the clunking associated with them
575 here....https://www.redline360.com/tein-coilovers-street-advance-z-camry-GSTE2-9USS2
TN の がしょう
2015 Camry XSE V6
Discussion Starter #284
I’m running that tein setup with no issues. Handling was greatly improved and no clunking whatsoever. I’m dropped conservatively with about 1.5 finger gap all around. OEM tophats are reused.
Larger Front Sway bar
I've done an internet search and a search of this thread and have not been able to find a company/part number for a larger front sway bar for my 2012 Camry XLE. Just found references to larger bars but no part number info. Can anyone help me out?
Also, is the SE front sway bar larger than the one in the v-6 XLE? If so, just how much?
TN の がしょう
2015 Camry XSE V6
Discussion Starter #287
I believe they are no longer available by manufacturers that did offer them.
Thanks for the answer, once again, a day late and a dollar short! I had checked Ultra racing and Progress and they only offer the rear sway bar kit.
Andy's Auto Parts listed a front bar from Progress and it turned out to be the Progress rear bar kit. And they were a bit snotty about sending the bar back for credit. Usual junk about all packing materials be intact or they will ship back at my expense just because of their catalog mistake. How do you open a package without damaging some of the original packaging?
Don't buy anything from Andy's Auto Parts, between no communication about late delivery and the hassle about returns, they ain't worth the hassle dealing with them. And they shipped only after I filed a PayPal complaint for non-delivery.
The ebay Ultra Racing dealers in Malaysia deliver in 3-4 days, go figure.
The online Toyota parts dealers seem to list the same front sway bar part number for both the SE and XLE, so that's out.
2012 Camry
my coil overs came with different end links.
TN の がしょう
2015 Camry XSE V6
Discussion Starter #290
It would help what manufacturer and model # you ordered. Also what engine your car has and if it's a hybrid or not.
2012 Camry
i have the 2012 SE sport limited edition. was special made model with TRD exhaust and BBS 18" wheels.
Megan Racing Street Coilovers for 2012-2014 Toyota Camry SE Model only - MR-CDK-TCA12S - (2014 2013 2012)
Vehicle Fitment 2012-2014 Toyota Camry SE Model only Front Camber Plate Yes Front Top Mount Pillowball Rear Top Mount Megan Rubber Mount Front Spring Rate 6 kg/mm Rear Spring Rate 3 kg/mm Notes Do not fit Camry 2013-14 2.5L SE Sport Limited Edition
TN の がしょう
2015 Camry XSE V6
Discussion Starter #292
I might know what happened. Wherever you bought it, probably sent you the non-SE version.
As crappy as it sounds, Megan Racing shows the similar model #MR-CDK-TCA12S for both Non-SE and SE only models. The only difference is the "S" at the end.
MR-CDK-TCA12 (Non SE)
MR-CDK-TCA12S (SE only)
See the website. https://meganracing.com/store.html?find=toyota-camry-2014-4495&sid=XBayiejBSY
My suggestion is that you contact Megan Racing directly and let them know what you were provided with the wrong MR-CDK-TCA12S and that you need one for the SE model.
2012 Camry
they gave me the 900$ ones for that with out charging me, so i paid 599$ for the 900$ ones cause of that mistake lol.
Account canceled
Masami,
About sway bars, I never did find anything other than the single OEM bar for the front of the car. It was used for all trim levels. For the rear, I think there were two OEM versions (16mm solid and hollow as I recall) and two aftermarket bars: 19mm and 23mm, both solid. I'm still using the 23mm bar and am over-the-top pleased with how the car handles. I still have the OE struts/springs.
Although the Camry has a highish center of mass (23" +/-?), with the OE front bar and the 23mm rear bar, roll is still quite tolerable - maybe a touch over 2 degrees at the limit of adhesion. This doesn't really leave me pining for a stiffer front bar, although the front could use more static negative camber. (One of these days I'll get to it.)
Best,
Mark
2016 camry se/240sx
just got some tein S tech lowering springs for my 2016 se on black friday on amazon 215$... ill be sure to post some pics once i install them...
2016 camry se/240sx
well i installed my tien lowering springs..feels pretty close to stock as far as ride quality, bigger bumps it soaks it up well not harsh at all, havent aligned it yet but it drives perfectly straight, may wait a few more days to see if it settles but ive measured all 4 corners upon install and this morning and its already leveled itself out.
288978
Anybody know what mm polyurethane bushings to use for the sway bar on a 2017 Camry se? Or if they even make them? Found universal energy suspension bushings for my 07 corolla and it was a huge improvement..
capncomatose15
2014.5 Toyota Camry
Currently working on saving for a set of either Tein or BC Racing coilovers and the Progress rear swaybar, hoping to get them ordered by the end of the month. Might be a guinea pig and try out the Siberian Bushings poly front swaybar bushings as well. I wish there was more aftermarket support for these cars. Does anyone have the Borla exhaust (either axle back and/or midpipes)? I'm considering ordering at least the axle backs for my 2014.5 SE V6.
TN の がしょう
2015 Camry XSE V6
Discussion Starter #300
Instead of Borla, have you looked into Vibrant exhausts and custom pipe it at a shop? I'm not a big fan of Borla because it tends to be too muffled for an aftermarket exhaust.
