After owning the 2020 limited for 10 months and only seeing 4,000 on the odometer, I thought I would do the initial oil change this weekend. Manual says yearly or 10,000 miles, but this year we certainly saw low mileage and in another 2 months, it would be January and in Ohio, that could mean either 40* or -20*, so with yesterday being 50 and sunny, I decided it was a good day.
For the DIY'ers, this is not the easiest oil change. The plastic engine guard/pan or whatever they call it is a real pain. It goes WAY the heck toward the rear of the car, so if you jack up the front end and put on jack stands, make SURE you are way up in the air. You can't see the rear fastener and have to release it by feel unless the car is really really jacked up. The next recommendation is to make sure you get a good tool to remove the oil filter housing, and definitely use a torque wrench to install the housing. It would be rather easy to over torque it and then make your life miserable the next time you went to remove it. The first time it took well over an hour, probably close to 90 minutes, I'm sure the next time it will be much shorter knowing what exactly to do and which tools to have at my side.
