1 - 16 of 16 Posts
TN Pussy Man
Camry
are the injectors for the 1jz, 2jz and 7mge and 7mgte all interchangeable- as in direct plug in with harness and everything?
cuz I'm looking for some bigger injectors for my s/c camry- somewhera around 310cc.
thanks guys!
Offical TN Hillbilly
2002 Silverado
In a word, no. If you need new Camry injectors then you will need to match up the impedance, and make sure they will fit the rail. You will also probably need a piggy back controller to correct the mix. Why not hit up the Camry forum for options?
TN Pussy Man
Camry
lol...no, I don't need new camry injectors. the camry injectors won't cut it since I went FI
and impedence isn't the greatest problem at this time. I just need ones that will fit the rail as well as the harness.
camry/solara people have been using supra injectors, but I'm not sure which ones. I've posted up on SolaraGuy, but SG moves really slow, so they're not any help yet.
and the camry forum isn't very good when it comes to real performance oriented things
thanks for letting me know that they don't switch up though. I asked the question because I saw posts in supraforums that had people saying that 2jz rails/injectors would drop into a 7mg setup....I guess not.
Super Moderator
Supra
If you could fab up a way to fit the rail you could mount jz injectors in the 7m, but as always, since the rail already works for any power anyone has ever made on the 7m, and the injectors are roughly the same price either way, I've never understood why people want to go to all the effort to fab up mounts etc.
You might try quizzing the folks at RC injectors (can't remember the website), or give raptorracing here an email/pm about availablility of drop in injectors, as well as specs that will work. If you decide on new ones, RC makes a well known, good quality injector, although they are a little more expensive the other brands. Stay away from Venom like it has plague!!! If you find 7M injectors work for you, and you need a working used set, let me know as I have a couple of sets of stock 440cc laying around.
TN Pussy Man
Camry
Discussion Starter #6
^ are the stock injectors denso injectors? because apparently any denso injector will mount up on my rails
and thanks for the offer, but 440cc is too much for my needs- it'd probably flood my engine...lol
Got Hardass?
The JZ Injectors and M series Injectors are not interchangable. The NA's would be, but they are far under even Mk3 NA's so there's not a point to for us Mk3 guys.
JZ's (minus the N/A) are all Side Feed, while M's are all top feed.
7M-GE (Mk3 NA - 1986.5 - 1992):
86-88 - Top Feed, Low Impedance (Yellow), 2.7ohm, 295cc, Type: Dual Ball Valve
89-92 - Top Feed, High Impedance (Light-Green), 13.8ohm, 315cc, Type: Dual Ball Valve
7M-GTE (Mk3 T - 1987 - 1992):
87-88 - Top Feed, Low Impedance (Black), 2.9ohm, 430cc, Type: Dual Ball Valve
89-92 - Top Feed, Low Impedance (Black), 2.9ohm, 430cc, Type: Dual Ball Valve
1JZ:
## - ## - Top Feed, High Impedance (Yellow), 13.8 Ohm, 380cc
2JZ-GE (Mk4 N/A, IS300):
Top Feed, High Impedance (Green), 13.8 Ohm, 315cc
2JZ-GTE (Mk4 TT - 1993-1998):
JDM - Side Feed, High Impedance (Grey) , 14.2 Ohm, 430cc
USDM - Side Feed, Low Impedance (Purple) 2.3 Ohm, 520cc
Stealing this from Toysrme:
Fuel Injector Calculator:
Size @ 80%-100% injector duration
315cc = 302hp-378hp
330cc = 316hp-396hp
350cc = 336hp-420hp
370cc = 355hp-444hp
440cc = 422hp-528hp
550cc = 528hp-660hp
720cc = 691hp-864hp
Yes, all stock injectors are Nippon Denso manufactured. However, as they're not all the same feed they all won't fit. So, you'll need to match the feed type, impedance (or use a resistor pack) and flow rate desired.
2002 Silverado
Not sure what the Camry rail looks like, but the guys running the 5VZ super charger use the green top injectors from the 2JZGE or the light greens from the 7MGTE. My guess would be that is what the other Camry/Solara guys are using.
Super Moderator
Supra
if those green tops work, post a WTB at the torontosupraclub.com site. I know there have been a few GE's parted out recently.
Got Hardass?
The 1MZ rails are much like the Mk3's. If the injectors are the ones I think they are,
1MZ-FE (V6, ES300/Camry 93-?):
Top Feed, High Impedance (Teal Colored), 14.7 Ohm, 244cc
I may be wrong however, the Denso numbers don't match :grumbles:
TN Pussy Man
Camry
Discussion Starter #11
lol
well, thanks for the help guys, but I finally found out which ones most of the supercharged camry/solaras use
they use the 2jzge injectors with high-impedence top feed and they are a direct fit (including wiring harness) on the camry fuel rails
I'm working with trd4life to get me some right now, but if the deal falls through, I'll post up on torontosupra for sure.
thanks for the efforts guys, much appreciated :thumbup:
TN Pussy Man
Camry
Discussion Starter #12
as well, that's the sort of thing that I keep on hearing, so that's why I get confused about the interchangeability of hte injectors
if a camry or other car can use either/or, then why can't the supras themselves interchange them, etc. etc.
but I digress....especially now that I finally found my answer :p:
I've got a set of 305cc injectors from a 2J NA engine that were going to be used on my 4Runner. If they are the ones you are looking for, LMK and we can probably work something out. They need to be cleaned as they have been out of an engine for years now.
Vic
93 240sx SR Hatch
1999 Solara
sorry to bump this up, but Im curious to know- I just got some 2jzge oem injectors from a lexus IS300. They look to be teal colored. I got them really cheap to upgrade my stock 1mz solara ones for 5.5 psi of boost. I only need a slight increase from the stock injectors to run safely. Do you guys know if these are the same injectors as the 2jzge supra ones? or are those different? I see above those are listed as green... got me wondering now.
Super Moderator
Supra
I'm not sure if the IS was the same injector, but I recall the rated power was similar to the 2jz-ge supra, so I would suspect them to be the same part. That said, I've never looked before. You might try one of the lexus forums out.
If they do turn out to be the same, and if I were you, I wouldn't install them as is for any level of boost. Send them for flow testing and cleaning. It's pretty cheap insurance that the injectors won't stick on you and you avoid ventilating a piston top...
Got Hardass?
Found this list laying around:
Heres a small chart of some stock injectors, sizes and resistance.
Top Feed
Engine Style Size Impedance* Years / Models
Nissan KA24E Top feed 260cc High S13
Nissan CA18DET Top feed 370cc Low S13
Nissan RB20DET Top feed 270cc High R32
Nissan RB26DETT Top feed 440cc Low R32/R33/R34
Mazda FC NA Top feed 460cc Low 86-87
Mazda FC NA Top feed 460cc High 88
Mazda FC NA Top feed 460cc High 89-91
Mazda FC turbo Top feed 550cc Low 86-87
Mazda FC turbo Top feed 550cc High 88
Mazda FC turbo Top feed 550cc High 89-91
Mazda FC NA Top feed 680cc Low 84-85
DSM 3000GT/Stealth turbo Top feed 360cc Low 91+
DSM Talon/Eclipse nonturbo Top feed 390cc Low 89-94
DSM Talon/Eclipse 1G Top feed 450cc Low 89-94
DSM Talon/Eclipse 2G Top feed 450cc Low 95-99
Mitsubishi Evo Top feed 510cc Low Evo 1-Evo 3
Mitsubishi Evo Top feed 560cc Low Evo 4+
Subaru WRX Top feed 420cc 02+
Subaru JDM STi Top feed 525cc 99+??
Toyota 3S-GE Top feed 295cc High
Toyota 7M-GE Top feed 295cc High Cressida, Supra mk3 NA
Toyota 2JZ-GE Top feed 315cc High Supra mk4 NA, SC/GS/IS300
Toyota 3S-GE Top feed 315cc High
Toyota 7M-GE Top feed 315cc High Cressida, Supra mk3 NA
Side Feed
Nissan KA24DE Side feed 270cc High S13/S14
Nissan SR20DET Side feed 370cc High S13/S14
Nissan SR20DET Side feed 480cc High S15
Nissan RB25DET Side feed 370cc High R33/R34
Nissan VG30DETT Side feed 370cc High Z32
NOTE: 90 - 94 Z32 uses a style of injector that is non-compatable with KA fuel rails (still sidefeed), while 95 - 96 uses the same injector as the RB25DET and SR20DET, etc.
Mazda FD Side feed 550cc High 93-98
Mazda FD Side feed 850cc High 93-98
Mazda 20B Side feed 550cc High JDM Mazda Cosmo?
Subaru JDM STi Side feed 550cc (565cc?) High pre 99
Subaru STi Side feed 565cc High 03+
Toyota 7M-GTE Side feed 430cc (440cc?) Low Supra mk3 turbo
Toyota 2JZ-GTE Side feed 550cc Low Supra mk4 turbo
Toyota 3S-GTE Side feed 430cc (440cc?) Low MR2, 91+
Toyota 4A-GZE Side feed? 365cc Low MR2, MK1
Toyota Celica GTS Side feed? 310cc High 2000+
Toyota JDM 1JZ-GTE Side feed 430cc Low Chaser, Supra mk3?
Toyota JDM 2JZ-GTE Side feed 430cc High?* Supra mk4 turbo
Toyota JDM 7M-GTE Side feed 430cc Low Supra mk3 turbo
Ford Turbo Coupe ?? 30lb (~315cc) Low 86-89
Ford Turbo Coupe ?? 35lb (~365cc) Low ??
Honda Prelude (H22A) ?? 345cc Low 92-96 VTEC
*Impedence
Saturated = High Impedence
Peak and Hold = Low Impedence
However, I know it's got some faults. The 7M never changed the injector feed.
1 - 16 of 16 Posts
