There are a lot of different GPS systems available for aftermarket and most can be configured with the right install kit to work with your steering controls. However it may or may not be worth the extra money to have the controls available since the kit required to make that work is usually around 50-80 dollars.Hi guys, I'm really new to these forums and now that I have set a little money aside I would like to start modding my 2010 Toyota Corolla XLE. I just need some help with some questions since I have never done this before.
1. What brand of GPS should I get? I would prefer stick with a stock GPS but if a after market is better and cheaper then I would do that. Budget for this would be around $300, but wold like to get it as low as I can!
2. Does anyone have a good installation video or post where I can read how to do it step by step and if I will need anything else extra wires or such.
3. On my XLE model I have volume and radio changing stations buttons on the left side of my steering and Bluetooth calling and voice commands on the right side. Will these work after installing the GPS? For example I install the GPS and go the radio function will I be able to change the radio station from my buttons like I had been able too.
If someone could please answer these questions I would greatly appreciate it!
I would start with Crutchfield or somewhere similar and just read through some reviews of GPS enabled systems and what works well and what doesn't.
At your 300 dollar price point you will be limited in what you will be able to get for an in-dash GPS system if that is indeed what you want. The good news is that the installation is very easy and should only take an hour or so. I have a Dual-Din Bluetooth Sony touchscreen receiver without GPS that I do like a lot here and the install was 45 minutes tops.
