1 - 3 of 3 Posts
· Killa Clean Gen 3
Camry
Hey guys,
My big ass supra TT rotors are about to be put on along with some V6 calipers.
Heres the question.
I need to remove the old calipers and put on the new ones, so can I just let all the brake fluid drain out and then refill with the new calipers installed and then bleed?
My concern is if I drain all the brake fluid out of the front, does it also take the brake fluid out of the rear, meaning that I would have to bleed the drums? I DON"T WANT TO MESS WITH IT IF I HAVE TO BLEED THE REAR!
Or are the two systems seperate and I can drain just the front brake fluid with no problems?
Also, How much brake fluid do I need to refill it when I'm done? Any recomened brands?
Thanks guys, pleanty of pics to come!
· Pochacco Owns Me
you can get a hose clamp so only a lil bit will drip out. i think they cost like 4$ tops if you don't wanna do that. you'll have to bleed the fronts again. and there's a max line on the resivor so just don't go over that.
1 - 3 of 3 Posts
