Just a quick question for the guys in the know. Are all 3E-E lower ends the same? (crank, pistons , con rods etc..) Tryin to find out if a '93 EFI head would fit on a '90 block--both 3E-E
Ok maybe not so quick, how do you get different bearing sizes for the crank and rod . I ordered a set of bearings and found no standard (1,2,3,4..) numbers to match those on the existing crank and con rod bearings --would these numberless wonders work?
Any advice would be greatly appreciated
PG
PG
