1 - 13 of 13 Posts
· back again? yeah, i am.
1992 Toyota Camry
i got the entire instrument cluster off no prob...i wanted to change these lights...the heating and ac switches, the ignition light, the lighter light, and i was gonna buy white faced gauges....my question is, what size are the bulbs for everything EXCEPT the gauges.... and how the hell am i supposed to get behind the heating and a/c switches to change the bulbs and change the ring around the ignition and lighter???...i want all the lights to be blue...thanks for all your help
there was a thread about this already...search for it and if it still didnt answer your questions then post back here. Im not sayin that just to piss u off cuz i hate it when people tell me i shouldve searched first, but it would probably answer ur question
1992 Toyota Camry
Discussion Starter · #3 ·
no...that thread was jus showing a guys interior lights...i actually have a specific problem that needs to be answered
· Gen5.5 Sportivo V6
04 Camry Sportivo V6
i dont know how to get to the bulbs behind the AC controls either, i unscrewed everything and it wouldnt come out, if i pull it hard, i was bound to break something :p:, so i left it alone for now.
anyway, the Ignition ring, Lighter, and ashtray are all 74 size bulbs as far as i know.....
they are easy to get out, just twist the bulb holder and out it comes :D
· permanent hiatus
if you guys had a pic of your ac knobs it might help... i have the xle trim and the knobs might be different. for me, i have 2 knobs, then all the buttons to the right of the knobs on the same panel.
once i got the dash off, i unscrewed the 4 tiny screws around the front plate around the ac knobs. next you have to undo the clips, there are clips on the top and bottom. it should come off once the clips are out. let me know if this helps
1992 Toyota Camry
Discussion Starter · #9 ·
^my haynes manual said to take the switch all the way to the left out....i dont kno how...there are clips?...
1992 Toyota Camry
Discussion Starter · #11 ·
ill get one sometime tom. i have to go to work right now...click on my sig and go to my interior pics..its the switch all the way to the left in the ac controls
· permanent hiatus
your ac ctrls are much different than mine, i only have two knobs. but the hot/cold knob (and the other ones) should be able to slip off. remove these first.
the clips are on the bezel around the knobs... this bezel also has screws. first unscrew the whole housing and pull it out a little to get a better angle at the screws. undo the screws around the bezel (they should be little ones) then undo the clips. let me know if you still need help
· Traitor
instead of starting a new thread...i've got a big favor to ask one of the mods....is it possible to sticky a master list of the interior bulb numbers for each gen camry...i think it would not only help me but it would also help others who want to replace their interior lights...the one 10 page thread about the interior lighting is too confusing to pull all the right info out of
1 - 13 of 13 Posts
