Can someone interpret these results? Car still pulls to the left and when I make the wheel straight it pulls more. It’s a 2009 camry. Tires are brand new all the way around
Camber is adjustble cuz there is 2 bolts on the bottom on the strut I thinkThe only thing I can see is that the left and right toes are different, ideally they should be the same. Amd the cambers are different also, but unfortunately they are not adjustable without using special bolts. I Would take the car back to the alignment shop and tell them to get it right.
The unbalanced Front cambers between Left (-0.60°) and Right (-1.10°) is inducing the Pull Left phenomenon, assuming the unknown Front casters and tires are non-issue for now.Can someone interpret these results? Car still pulls to the left and when I make the wheel straight it pulls more. It’s a 2009 camry. Tires are brand new all the way around View attachment 385697
What do u mean by this?The unbalanced Front cambers between Left (-0.60°) and Right (-1.10°) is inducing the Pull Left phenomenon, assuming the unknown Front casters and tires are non-issue for now.
The front cambers are adjustable with Toyota bolts (of differing part #s) or after market eccentric camber bolts.
Tire (uneven) wear wise at front axle, you're likely to be able to get away with it by doing nothing other than Pull Left irritation.
I meant to say uneven wear on front tires (between insides and outsides) are unlikely, without rectifying the Pull Left/unbalanced cambers at front not suggesting you should ignore it.What do u mean by this?
I dont even think the tech made the steering straight when doing the alignement so in that case, if we do it again and the steering is straight while doing the alignement, the toe angles will be off again.I meant to say uneven wear on front tires (between insides and outsides) are unlikely, without rectifying the Pull Left/unbalanced cambers at front not suggesting you should ignore it.
You're probably right in suggesting the alignment tech didn't properly centre and straighten the steering wheel before making adjustments to front toes.I dont even think the tech made the steering straight when doing the alignement so in that case, if we do it again and the steering is straight while doing the alignement, the toe angles will be off again.
An 'incomplete' 2-Wheel Alignment was done on the car, whereby the front camber (that requires adjustment in your case) was not adjusted by the alignment tech.Is a 2 wheel alignment performed on these car or 4 wheel alignment
Yes, caster (front) can be measured though 'difficult' to adjust as typically found in modern cars' Front McPherson Struts suspension designs provides no factory adjustment. After market top caster/camber plate would help though.We're just gonna go to another shop since there arent gonna do a good job. Most people avoid the shop but we went there to get tires since we got 24 month financing. Yeah u are right, it wasnt done incorrectly. I think the front caster can be measured can it?
The 'Before' measurements of this Alignment No.2 from another shop appears drastically different from that of previous alignment 'After' measurements though mechanical conditions of suspension remains the same.View attachment 388220
Here’s the alignement report from another shop. Toes were way off on the inital reading then the final readings at the initial shop. This could be caused by bad tie rods messing up the alignment but who knows. Its good for now will have to see.
He adjusted the rear left toeThe 'Before' measurements of this Alignment No.2 from another shop appears drastically different from that of previous alignment 'After' measurements though mechanical conditions of suspension remains the same.
My hunch is the Alignment No.2 maybe more accurate than the previous one and its 'Before' measurements is consistent too with pull/drift left phenomenon you described earlier.
This current 'After' adjustment has vastly 'reduced' the car's propensity of pulling/drifting left though it may not have been eliminated imho.
Just curious if you saw the alignment tech walk up to and make adjustments to rear left toes? Or he did not?
Ahh..... then the tech should have equalized the rear left toe value similar to that of rear right for 0°00' thrust angle since he was in it, before proceeding with front toe adjustments.He adjusted the rear left toe
