1 - 8 of 8 Posts
Basically I am wondering if it is possible to swap the stereo / entune / infotainment system between 2022 - 2023 mode into 2020 Camry. It would see that the entire section of the dash would need to be swapped because the vents are in a different place, but does anything else need to be swapped? would it be plug and play connector wise?
I have the 2018 Camry XSE, not 100% sure what the model ID for the head unit is but it is inside the dash whereas the newer Camrys are "pop up" at the top of the dash. I would assume that I couldn't just pop a newer one into my Camry.
Discussion Starter · #7 ·
I think the whole dash trim has to be replaced, but if the wiring is plug and play then it shouldnt be too difficult.
You could try this and it is wireless to your phone.
1 - 8 of 8 Posts
