So on the way to have my bearings changed my corolla started knocking. At least at first I thought the engine was knocking, but after a day of checking the motor all over and driving it in varying conditions I'm confused. The noise only happens after driving for awhile, maybe 15 minutes or so which leads me to believe it's not the dreaded death knock but maybe an accessory failure. I stuffed my head into the engine bay while the car was running and the sound appears to come from the water pump/timing belt tensioner area. Also knocking doesn't usually just come and go for no reason with no ill effects on the engine (or idle) so what could this be? Has anyone heard anything like this before? Do you think maybe it's my timing belt tensioner?
I attempted to add my youtube vid but toyotanation is throwing a hissy fit (basically every time I use this website actually). But anyway here it is
