I am replacing the fuel filter on a 1996 Camry 5SFE. I already have a new Wix filter. The car originally came from Wisconsin and has rust. I used a flare wrench to try to remove the fuel line from the filter, but it absolutely would not work. I had to cut the line. Now, I'm having a problem in reconnecting the new filter to the line. I can cut out a section of the fuel line, flare it, bend it, and get a 14 mm fitting, which goes into the filter. I was then planning on connecting the line from the filter to the rest of the line (where I will cut it) and connect it with fuel injection hose and clamps. The guy at the parts store told me that any screw clamp will not withstand the pressure from the fuel injection line and will burst or become otherwise dangerous and that I should only use metal compression fittings. I thought as long as the rubber hose I am using to connect the two ends of the fuel line is the type made for fuel injection, then it is not a problem using a couple of screw-type clamps to secure the rubber hose to the steel fuel line. Is the parts store guy right, or is it perfectly fine to do what I was planning?
