I'd say that you probably for sure want to replace the timing belt, cause if that goes, it's bye bye motor. I don't know about the other stuff though
95WhiteCamry said:here's the list of the things they told me that had to be done and their prices including labor:
- timing belt (169.99)
- fix distributor o ring leak (127.00)
- replace transmission pan gasket (199.06)
- reseal oil pan (506.00)
- valve adjustment and change drive belts (627.00)
How many miles does your car have?95WhiteCamry said:Well, I brought the camry in to the dealership today to get my oil changed (they had a special) and they offered a free inspection so I said "eh, why not?"
After all was said and done, I paid 19 dollars for an oil change and got a hefty list of repairs that need 'immediate attention'
well that's good to know. Because according to my dad's mechanic, my car would've needed a new motor if the timing belt went...oh well, it's in the pastLuckynumber5 said:^ No... its not bye bye motor, none of the Camry engines are interference engines![]()
thanks!Cyorke said:I have to agree with zoni on everything.
Sorry guys, some of you just have a hatred for dealerships. There aren't the only solution to problems, they are an option. My camry is dealer-maintained. I know i pay a little extra for the work they put into it. But not all work is performed there.eyeball96 said:Just stay away from the stealerships!! Take your car to a mechanic you trust!
Timing belt...good idea.... The rest just keep an eye on your driveway and oil level! You'll be fine!
