1 - 8 of 8 Posts
1994 Corolla DX
I do not know conclusively so consider my statements "armchair diagnostics". I'd be worried about the metal "dust" forming from the physical contact between the rotor and the distributor cap contact points. That "dust" would be conductive and potentially cause electrical issues.
1997 Corolla
If Toyota put it there, then you need it.
i believe it's a heat shield and not a dust cover. u could use some other sheet metal, cut it to similar dimension and bolt it on. it doesn't have to look pretty , it just need to be there the shield the heat from the engine getting to the dizzie.
1994 Corolla DX
No.
The part is literally called a "cover, dust proof": https://www.toyotapartsdeal.com/oem/toyota~cover~dust~proof~19121-11080.html
And if it had a significantly heat shielding effect it would actually make things worse because of where it sits. It does not sit between the engine and the distributor. It sits between the distributor internals and the rotor. So if it truly acted as a heat shield it would increase the temperature of the distributor internals.
1997 Corolla
You don't want dust on the coil or it may increase arcing and cause a weak spark. I think putting something metal there in its place would not be good because it could conduct electricity away from where it should go. The distributor will probably work without the cover there temporarily, but you probably want it there long term. If it just has a crack then you can probably just keep using it without any ill effects.
1993 Corolla
How badly is it cracked? You could probably get one from a salvage yard or order one from the link above. Either way it is cheap insurance. They put it there for a reason.
1 - 8 of 8 Posts
