Is there a cabin air filter in the 1997 Toyota Tacoma? It is the 2.4L with ext cab. Where is the best place to order it/
If the previous owner smoked, the tar will stick to everything. If he used the fan in Recirc mode a lot, it will coat the inside of vent tubes and will send that smell out when warm or when a lot of air flows across it.
If the AC was used a lot, the moisture left in the lines can mold/mildew a bit and be a pain to get rid of the smell. It's recommended to run the fan for 5 minutes with no AC after running the AC for a while to help dissipate the moisture.
