Haynes isn't much use in this department, and a search comes up empty.
There is one hose that is capped(although, I'm not sure what it's for, a mechanic I took it to said he had no idea what it was for, it is attached to the back of the engine somewhere). There is also this issue with the coolant pipes,as it looks like someone clamped one of the pipes, but I'm not sure if it cuts off coolant or not.
My engine is not overheating, as far as I can tell. But there is a rough idle, which I think is due to a clogged EGR valve(vacuum pump test seemed to confirm it's clogged), but I could be wrong.
