1 - 4 of 4 Posts
I'm replacing a seized motor in a 96 Corolla wagon, and while I've got it all out I'm replacing a bunch of seals and gaskets. I'm looking for a list of torque specs, and I've found the major components like crank, rods, and head, but can't find listings for the little stuff like oil pan bolts, torque converter bolts, water pump bolts, bellhousing bolts, etc, etc.
Is there a comprehensive list that exists anywhere? I couldn't find anything here, or on Google. I hate to think my search skills are starting to decline.
Thanks
Discussion Starter · #2 · (Edited)
Found one. My local library has a subscription to a Chilton's reference database, and there was a list. For the sake of anybody doing a search in the future, here you go. For some reason the list doesn't include alternator or A/C bolts. I've seen A/C mounting bolts listed at 18 ft.lbs for other Toyota engines, but I don't know if that's accurate for the 4 and 7 AFE motors.
There was also no graphic showing which of the A245E transaxle retaining bolts are the A, B, C, or D bolts. I assume the larger the bolt, the more torque.
4A-FE and 7A-FE Engines 1993-1997
Alternator bracket to cylinder head 20 ft.lbs
Camshaft timiming pulley 43 ft.lbs
Center member to body (A) 61 ft.lbs
Center member to body (B) 64 ft. lbs
Center member to body (C) 48 ft.lbs
Center member to body nut 57 ft. lbs
Connecting rod cap to connecting rod 4A-FE 1st 22 ft.lbs
Connecting rod cap to connecting rod 4A-FE 2nd Turn 90*
Connecting rod cap to connecting rod 7A-FE 1st 18 ft.lbs
Connecting rod cap to connecting rod 7A-FE 2nd Turn 90*
Crankshaft pulley 87 ft.lbs
Cylinder block idler pulley 27 ft.lbs
Cylinder head camshaft bearing cap 9 ft.lbs
Cylinder head cover 52 in.lbs
Cylinder head delivery pipe 11 ft.lbs
Cylinder head distributor 14 ft.lbs
Cylinder head to block 1st pass 22 ft.lbs
Cylinder head to block 2nd pass Turn 90*
Cylinder head to block 3rd pass Turn 90*
Drive plate (automatic) 47 ft.lbs
Engine mounting bracket to block 38 ft.lbs
Engine mounting insulator RH body (A) 47 ft.lbs
Engine mounting insulator RH body (C) 19 ft.lbs
Engine mounting RH insulator bracket bolt 47 ft.lbs
Engine mounting RH insulator bracket nut 38 ft.lbs
Exhaust manifold stay to cylinder block 29 ft.lbs
Exhaust manifold stay to manifold 29 ft.lbs
Exhaust manifold to cylinder head 25 ft.lbs
Flywheel (manual) 58 ft.lbs
Front engine mounting bracket to transaxle 57 ft.lbs
Front engine mounting insulator to bracket 87 ft.lbs
Front exhaust pipe to catalyst 32 ft.lbs
Front exhaust pipe to exhaust manifold 46 ft.lbs
Fuel inlet hose 22 ft.lbs
Intake manifold stay to bracket 29 ft.lbs
Intake manifold stay to manifold 14 ft.lbs
Intake manifold to cylinder head 14 ft.lbs
Intake manifold to cylinder head 7A-FE EGR port 9 ft.lbs
Intake manifold to cylinder head 7A-FE others 14 ft.lbs
Knock sensor to block 21 ft.lbs
Main bearing cap to cylinder block 44 ft.lbs
Mounting bracket LH 38 ft.lbs
Mounting braket LH to mounting bracket 56 ft.lbs
Mounting isolator LH to body 87 ft.lbs
Mounting stay LH to insulator 21 ft.lbs
Mounting stay LH to transaxle 21 ft.lbs
Oil dipstick guide No. 2 water outlet 82 in.lbs
Oil pan No. 1 to block 7A-FE 12 ft.lbs
Oil pan No. 1 to oil pan No. 2 7A-FE 43 in.lbs
Oil pan to block 4A-FE 43 in.lbs
Oil pan to oil pump 4A-FE 43 in.lbs
Oil pan to oil pump 7A-FE 69 in.lbs
Rear engine mouting bracket to transaxle 57 ft.lbs
Rear engine mounting insulator to bracket 87 ft.lbs
Rear oil seal retainer to cylinder block 82 in.lbs
Timing belt idler pulley to block 27 ft. lbs
Torque converter bolts (coat with Loctite®) 2WD 20 ft.lbs
Torque converter bolts (coat with Loctite®) 4WD 34 ft.lbs
Transaxle retaining bolts A131L, A240L and A241H
- 12mm bolts 47 ft.lbs
- 10mm bolts 34 ft.lbs
A245E
A - 17 ft.lbs
B - 18 ft.lbs
C - 34 ft.lbs
D- 47 ft.lbs
Water inlet housing to cylinder head 14 ft.lbs
Water inlet No. 2 cylinder head 11 ft.lbs
Water outlet to cylinder head 11 ft.lbs Water pump pulley 7 in.lbs
Water pump to cylinder block 11 ft.lbs
Head Human body Organism Gesture Rectangle
Automotive design Font Auto part Motor vehicle Engineering
Arm Human body Gesture Line Font
k
EDIT
Found this graphic on tcorolla.net indicating bellhousing bolt torque. They list 3 bolt sizes, whereas Chilton's lists 4, but with a spec of 18 ft. lbs. vs 17 ft. lbs., I'm guessing the difference is insignificant.
Slope Font Parallel Circle Triangle
1997 Corolla
Nice and thanks!
If you're doing any involved work it's best to get a used factory repair manual. On ebay now you can get a 1996 Toyota Corolla Repair Manual for $80 and the 1996 wiring diagram manual for $30. Having the torque specs is great, but sometimes there are some details in the repair manual, like what order to torque the head bolts, or to do the final torque on some suspension bolts with the wheels on the ground.
There may be some errors in that list which were in the factory repair manual. The 7 in-lbs for the pulley to water pump is ridiculously low, and probably should be 7 ft-lbs. I think I've brought this up before. I've come across some others in the repair manual, usually giving the wrong units like that.
Reactions: Apples555
Discussion Starter · #4 ·
I agree with all that, especially the 7 in. lbs. I like having a factory manual, but in this case I've crunched for time, between weather and a deadline on when a rental car has to be turned it. But yeah, factory manuals are an awesome source of info.
1 - 4 of 4 Posts
