Re: Is there anyone out there who can tell me how to replace atail...
have a 97 corolla. same lights as yours. when you remove the screws you
see when you open the trunk and the one nut (one i think) from the
inside of the trunk everything is off and the light assembly should come
out. take a screwdriver . put a rag around the blade as no to scratch
the car.pry straight out on the side of the fender where the light
assembly wraps around. proudly just stuck.once you get it removed the
first time it should be ok. remember mine was a bugger the first time.
had it about 7 years before i needed to replace any bulbs. good luck..
