1 - 3 of 3 Posts
This is only for those who swapped the manifolds and throttle body from a celica or newer corollas.
I want to know if you guys have the same thing as i do...
i tried to wiggle it and move it to so that the TB covers the gap but nope.
does that appearing hole should be covered???seems like the new manifold is quite a little small not covering enough of the bottom part like the stock intake manifold does.And that whole isn't like a thread hole or where a bolt can bolt on.
Would those two gap and space cause me to lose my mpg??
i dont think that will affect anything. you might just be seeing a gap since toyota switched over to using a o ring to seal the tb and intake manifold to the head instead of conventional gaskets. so they can have what appears to be a gap, when the o ring is perfectly sealed.
as for the hole, i dont know what it is or where it goes. all my heads have it. none of my plastic manifolds cover it.
1 - 3 of 3 Posts
