1 - 2 of 2 Posts
· Canyon Killer
Hey guys,
need some help from someone with some experience. I am about to buy 2JZ IS300 injectors off a fellow toyotanation member, and I was curious about the fitment on the 97 1MZ's...If it is a direct fitment, I have an A'Pexi SAFC-II to control the A/F ratio, along with a wideband A/F and I am already getting really good numbers in terms of CFM (dont remember what they were exactly, but they were above stock - I am using a 4.6L intake filter... .5% resistance on air flow on the total system). If I upgrade the injectors, do I absolutely NEED to turbo it or anything, or if I control the A/F through the SAFC, can I upgrade the injectors, without any other fuel management mods? keep in mind that this motor will eventually be turbo'ed, so ill need the injectors sooner or later.
· My other car is a Camry
Camry
Hey guys,
Don't buy them,,, The IS300 injectors are not the same as the Supra NA injectors. IS300 comes with 290cc/min stock, which is actually nearly the same size as the stock 1MZ-FE ones, if not, smaller...
As for fitment, they don't fit too well either because the seals on the intake manifold side look different compared to the 1MZ-FE ones as I recalled.
Hope you see this reply in time... DON'T get those injectors!
1 - 2 of 2 Posts
