Ok, I currently have the non JBL 6 disc system and really want to upgrade it. I'm starting with the speakers and will eventually get an amp and headunit probably no sub, but I wanted to know people's thoughts on these JBL speakers. My question was what's the deal with the ohm rating. Will they sound alright with the stock headunit w/o an amp, ect for the time being? Most speakers I've seen are 4 ohms, but these are 2 ohms, and I did some research and learned that lower ohms require more power or work from your headunit possibly resulting in overheating and frying basically. So will these be ok or do I need to look at something else? Also for the back (6.5's) should I stick with a speaker that is similar to the front, specification wise? I will probably get an amp (which i'm clueless about) in the future and want to get a nav headunit (pretty set on the Eclipse AVN6600). Anyway any suggestions would be greatly appreciated. Thanks.
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO937&Language=ENG&Country=US&Region=USA&cat=MEL&ser=GTS
