1 - 2 of 2 Posts
I have a 2000 Camry XLE V6 with the JBL premium sound system. Sooner or later, I want to put my Alpine headunit in and I have a couple of questions;
1) How many speakers are there? The brouchure says 6, most sources online say six, but my Munroney Sticker (window sticker) says I have 8. I know up front there is the set in the lower door and a set of sail panel tweeters, but what's going on in back?
2) What's the resistance of the speakers? I've seen online they are 2 Ohms instead of 4 Ohms.
3) Do the fronts, and if applicable, the rears, use a crossover or are they run in series, or parallel?
Look in sig
The JBL setup for the Gen4 should be
Front 6.5"
Rears 6x9"
Tweeters (don't know what size) on front door.
I know sometimes manufactures will count '2 way speakers' (with tweeters) as 'two' speakers on one.
JBL is a little different. I know for the Gen5 Camry, the setup is a bit different than the stock speakers/audio. You will have to bypass the amp.
1 - 2 of 2 Posts
