maybe I'm not phrasing right. I want to make some small upgrades. I will rebuild the motor sometime in the near future. My son has a probe gt. He wants to put in a klze j-spec engine. the only difference between the two is ecm, intake manifold, camshaft specs, and .5 points in cr, block is the same. Now a klze can be had for about $1000, but to do a rebuild using the klze parts would be considerably more than just buying a replacement and dropping it in. I want to know if the same holds true for this engine. I dont plan on going crazy, just want a mild HP increase and a newer motor.
thanks
