i do not propose to do it the same way that it is designed now.
i was thinking of moving the plenum more towards the middle.
that way it will be easier to change out the plugs and it would create less stress on the lower manifold.
if you notice how it hangs back over the rear bank of the motor, it adds to the stress on the motor mounts aswell.
also alot of the gen5 camry's have a plastic manifold that gm has used in the past and gm has had problems with it in the past.
this new manifold can be universal for all 1mzfe motors not just gen3,4 or 5's
so this could benifit al the camry generations.
and as for the 5sfe motor aswell in celica's,corolla's,camry's,avaolon's,solara's,and a possibility for mr2's.
so tell me if it's not worth it.
*if i honestly knew how to work with fiberglass and cf then i would have done it already. but i don't and i'm gauging interest to see if someone who does might jump in and take over.
in all honesty we spend money on glo gauges(just for looks), neons(also just for looks),dash kits(looks?),and cheap ebay ram air intakes(performance?or just a waste the you could have buit for less?).
cf hood=reduces weight that is on the car nearest to the top.
cf trunk=reduces weight that is on the car nearest to the top.
lower spring=bring the ride height down to lower center of gravity.
struts=help keep the wheels planted
swaybar=prevents roll
brakes=help stop the vehicle better
rims=lets the brakes breath easier
tires=more rummer to road to gain traction
exhaust=lets the motor perform better
intake(f/i or cai)=improve motors breathing capabilities
p&p=increase flow going into motor with minimal restriction
we do all this to help the car why not go one step further?
cf intake manifold=reduce the weight heighest up on the car also reduces intake air temperatures, improves air velocity, increases tq and hp (if done correctly). aswell as makes it easier to perform a tuneup and make it easier to look over the engine.
a spacer will not allow the brackets that are holding the plenum up to connect also bringing the manifold at an undesired angle.
edit*as for the cost i didn't even mention price. cause i don't know how much it would cost and if a group buy was to be done it might work out for all of us and alot quicker than the other gb i've seen since i'v been here.
