Load you up, eh? You asked for it......
Spark Plugs: NGK or Denso ONLY!!!
It's best to use a genuine Toyota distributor cap for proper moisture control. Might as well use a genuine Toyota rotor while you're at it.
Genuine Toyota plug wires ONLY!!! You'll understand why when you install them.
Rebuild the carburetor!! It'll run better than is has in years if not decades. Here's a great link for rebuilding the original Aisin carb.
http://www.bluebassdesign.com/boonin/carb_faq/
Here's another thread
http://www.toyotanation.com/forum/showthread.php?t=218658&highlight=rebuild+carb
Adjust the valves. .008 intake .012 exhaust with the engine hot.....or .007 intake .011 exhaust with the engine COLD. Do not over tightened the valve cover!!
Replace ALL of the vacuum hoses. Chances are they're original.
Replace the PCV valve
Use Mobil 1, WIX, Napa Gold (made by WIX) or genuine Toyota oil filters ONLY!! They have the best functioning anti-drain back valves on the market for the timing chain tensioner to prevent excess wear on the timing chain.
Replace the shifter seat and bushing for the transmission. It will solve all kinds of shifting issues.
http://www.4runners.org/writeups/shift/index.html
http://www.off-road.com/toyota/tech/shifter/index.html
http://www.brian894x4.com/Shifter.html
Replace the trans fluid with synthetic Redline MT 90. It has special additives that won't attack the brass syncros. Get ready for butter smooth shifts.
Replace the rear end fluid with Redline synthetic 80-140. Get a new gasket washer for the fill and drain plugs.
Swap out the 4 speed trans for an overdrive 5 speed. It's a direct swap!
http://www.toyotanation.com/forum/showthread.php?t=186759
http://www.toyotanation.com/forum/t205069.html
Repack the wheel bearings with grease. Don't assume that they have been done anytime soon or even at all. You'll need a new seal to service the inner bearing.
Flush the brake fluid.
Flush the clutch system (use brake fluid).
Drain and refill the cooling system. Use 50/50 coolant to water ratio. Use distilled water!!! Take a look at the radiator fins. If they have any build-up on them, replace the radiator. Replace all of the coolant hoses if they look original or brittle. Replace the thermostat with a genuine Toyota 2 way valve. Here's why:
http://www.4crawler.com/4x4/CheapTricks/index.shtml#Thermostat
Timing chain replacement procedure
http://www.4crawler.com/4x4/CheapTricks/EngineMods/TimingChain.shtml
Check the vacuum advance diaphragms for leaks. Then inner diaphragm (closest to the motor) is the most common one to fail. Pull a vacuum on the each port independently by using a vacuum pump or just suck on the hose. They both should hold perfect vacuum indefinitely.
That should keep you busy for awhile
