Ok.
I got this remote starter/alarm/door unlocker thing. So that I can do keyless entry on my 1999 camry. I wired it properly and connected it to the unlock and lock wires to my door lock system. Essentially it's connected directly to the wires that run to the rocker swtich on the driver side. I notice the following weird with the Camrys. If you are sitting in the car and unlock the door with the rocker switch and while having the door open push the rocker switch to lock the door and then close it. You can't unlock the door with the rocker switch unless you manuall unlock the door from the inside. It's a little problem becuase if I happen to leave my car and while having my door open hit the button on my transmitter to lock my car then close the door I won't be able to unlock it unless I manually unlock it with the key. This seems like some sort of weird security setting I don't know about???
