This was originally a PM to Cam. Like he pointed out in his previous post about PM'ing him, I can probably get some good answers from others on here:
--I just had my set of Premier's installed. I am running them off an Alpine MRV-F345 (rating sheet with amp had it at 101 watts per channel), connected with a Kicker PKD4 amp kit, Stinger Pro (I think it is called) speaker wire, and have Marv's baffles (including the ones for the tweets). I am soon to order Raamat, as well.
My first impression was that I wasted my money. It sounds better than the stock speakers but not by what I was expecting. I know that I definately need a sub cause I was expecting to have bass levels similar or better than the stock set up but this is not the case.
After I put on some good quality recordings (quality of sound varied A LOT depending on the track being played--they were downloaded from Itunes), I started to like the sound better.
This is my first system and I know that I need to have a sub but should I wait to judge the sound of these speakers until I get one or are they going to sound similar but with bass? They are nice but I wasn't blown away like I have been hearing other set ups like my buddy running Boston Pro's in his Envoy.
As far as sub, I did some research on the IDQ10 like you recommened and I'm going to go with that. The guy installing the system said I need the dual 2 ohm version since he'll bridge channels 3 & 4 (Alpine advertises 300 watts from 3/4).
The box you recommeded:
http://cgi.ebay.com/Toyota-Tacoma-Extended-Cab-05-07-Lg-Console-Sub-Box_W0QQitemZ220073197273QQihZ012QQcategoryZ50565Q QrdZ1QQcmdZViewItem
This has .75 cu ft of air space but ID (I called them) said it would be too big and that .50 to .60 cu ft is best for the IDQ10. I then called the box maker and he said I could just put some wood or styrofoam pieces in the box and secure them with double-sided tape and that should cut the air space down to the desired level.
Is that a viable option to cut air space and make that sub shine?--
I hope that some extra wood secured in the box will be fine cause I really like the box but will not sacrifice sub performance for it.
Thanks for the help!
