1 - 1 of 1 Posts
Speedkar99 on YouTube
2003 Camry
Here's whats inside and underneath the new Kia Forte and how it works!
The Kia Forte comes with a 2.0L 4-cylinder that is just port injected:
With the air intake removed, you can see the EGR components, throttle body, transmission and cooling system:
The transmission is one of Kia's first CVT's. From the top you can see the fill port and cooler:
Taking a look behind the headlight, we have a plastic radiator support. Seems sturdy up top:
While the drive belt is easy to come off, changing the water pump is really tight against the frame:
Despite all the plastic underneath, they do leave holes in it for the oil filter and drain plug:
Here's a look at the CVT from underneath:
The plastic radiator support is very flimsy down below which means no front jack point:
The rear suspension is typical economy car torsion beam:
The front suspension is a simple McPherson strut setup:
-Enjoy
1 - 1 of 1 Posts
