1 - 4 of 4 Posts
I got the CEL, and it would come and go. Luckily I was able to get a smog check here in Southern California during the time it was gone. It came back the next day. I was surprised the drive cycle had completed after reset the day before. So I took the opportunity to pass smog.
I want to perform that splice that cuts the connection to Knock Sensor 2 at the ECM and taps into the Knock Sensor 1 wire. Basically knock sensor 1 wire is feeding into the ECM for both Knock 1 and Knock 2. This was performed by another member, and I have been taking my time researching. I have the glove box off, and noticed that my wires are both WHITE. No Black for Knock Sensor 2.
As can be seen by the one wiring diagram I downloaded it has a "W" next to each knock sensor, so in some cases if I am dealing with the correct vehicle maybe my knock sensor wires are both white. I grabbed the picture of Bobster, that showed his black and white splice. So what do you think, just do the same splice but my wires are
293703
both
293704
white
293701
293702
Super Moderator
Yes, I think you've got it correct.
FYI
1 - 4 of 4 Posts
