Hey everyone,
my 09 Corolla S has recently had a "knocking" or "rattling" issue when accelerating after the car has warmed up. This noise does not occur until the engine is near being completely warmed up. It's most noticeable (or only happens) at low speeds and between 1300-2200 RPM. The only changes I have done recently are get a new alternator (3rd one on this car in the last 60k miles, previous one lasted like 1-2yrs), 4 new all-season tires last month (along with 2 new TPMS sensors that I'm sure they screwed up while putting new tires on), and changed the oil about 3-4k miles ago. I took it to a mechanic near me (that also did the alternator, tires, and TPMS) and they said the noise is coming from inside the engine, so it could be the timing chain or vvti stuff. They will need to take apart the engine and keep the car for about a week, giving me an estimate of minimum $1000.
Now a little bit about this mechanic, let's call them Rob Dumerel:
I've had issues with this mechanic in the past. I took it to them when one of my cylinders was misfiring, and gave them the error codes and explained everything. Check engine light was on so they could definitely pull the codes, especially if I was using a Bluetooth OBDII adapter with my phone. I get a call saying they need to clean the throttle body for $130. Not sure how an error code specific to cylinder C means throttle body, but I digress. I said go ahead and do it because they're the mechanic and they know better, so they did. When I picked up the car, I didn't even get out of the parking lot before I experienced another misfire and check engine light coming back on. Did research on the engine code, went to Autozone and bought a new spark plug, replaced it myself for $80 and got a $130 store credit at the mechanic. This is just one of the many stories my family has.
Back to the main point. I can't be without my car for a week, and definitely don't want to spend over $1000 as a current full-time student. I've read online that it might be the MAF, and others are saying VVTi or timing chain. One is much much more expensive than the other.
Here's what I've done so far:
What I'm tempted to try:
So if anyone has any idea or tips as to what it could be, please help me figure it out. I can post a video that has audio of the noise, but it's much different in person.
Edit: specified my model, S. I also have a Weapon-R Short-Ram intake that has worked fine for the past few years.
- check for loose paneling
- mechanic said my oil levels were fine
- check the throttle body for any carbon buildup
- I always use unleaded (87) gas
- I might need more coolant
- higher octane gas
- clean the MAF
- put factory air intake back on
- re-calibrate throttle body
