I stumbled upon these wheel spacers for 4&5 x 114.3
According to the spec sheet, ID is 75mm. My question is, if the center bore is 54.1mm for the Corolla, is this a risk even if the center bore is much larger?
It will basically mount to the hub and use the existing pcd of 5x100 and change to 5x114. My concern here is will this cause stress to the wheel bearing because of it being oversized?
Thanks.
www.nengun.com
Thanks.
KYO-EI - Wheel Spacers
KYO-EI have now introduced their quality made and designed Wheel Spacers.
