I have a 94 camry with the v6. When I start in the morning, it is very doggie. Sluggish, then about 1/2 mile down the road, it is fine. During this first half mile, it seems to not shift into 3rd, but once it gets warm, it is fine. Any suggestions?
maybe that why i let mine run for 5 10 mins top lolWhen the tranny is cold, it doesn't want to shift up gears because it's trying to warm up so that the lubricants work better. It's more apparent in large trucks, where they won't even shift out of first year until a certain temperature is met. When it gets colder, it'll become more apparent.. just don't run the car to the ground right when you start up the car.. or let it idle for a minute before driving.
normally you're bang on with your posts, but this one I will have to sit out for. Not sure, but I definitely think that isn't right. My car shifts to 3rd and even 4th if need be when it's cold. Then again I don't usually go right to highway speeds when the car is cold. Computer is programmed to set the shift point higher for that simple reason, to warm the engine. Higher shift point = higher rpm's = car warming quickerwhen the car is cold,by default it wont change to 3rd gear.
What ya mean default never heard that before my tranny when cold goes into third![]()
just try letting it sit for a couple minutes before you leave
yes, i noticed same thing on my V6. it starts upshifting normally once it gets warmed up, but before that in city driving it uses only 1st & 2nd gear.when the car is cold,by default it wont change to 3rd gear.
