1 - 17 of 17 Posts
I
Guest
Can anybody tell me which years the Land Cruiser had factory locking front
and rear differentials?
H
Guest
Discussion Starter #2
> front and rear differentials?
1990 to 98 on 80 Series. Up until current on 105.
May have been optional extra in some geographic areas.
Huw
J
Guest
The Land Cruiser that I know of only has a locking Center Differential. It
can go from what is effectively All Wheel Drive to 4 Wheel Drive. The
difference being that all wheel drive can be left on -- or is on -- all of
the time, and 4WD can only be used on dirt or snow and ice -- surfaces where
traction is "compromised" and the tires can slip and slide to release the
stress of going different speeds and distances.
"INDIVIDUAL" <[email protected]> wrote in message
news:[email protected]
H
Guest
> Differential. It can go from what is effectively All Wheel Drive to 4
> Wheel Drive. The difference being that all wheel drive can be left on
> -- or is on -- all of the time, and 4WD can only be used on dirt or
> snow and ice -- surfaces where traction is "compromised" and the
> tires can slip and slide to release the stress of going different
That version is full time 4wd with a locking centre diff. It was also
available with either a limited slip rear diff or an electrically actuated
mechanical diff lock on the rear and a similar diff lock on the front. This
is with rigid axles all round. It could also have a semi floating or a full
floating rear axle type.
The independently sprung front end models that have been available since '98
also have a centre diff lock with many having a rear diff lock as well. Some
have electronic traction control available.
Also available in many areas still is the rigid axle models, some with part
time 4wd where road work is accomplished with drive to the rear end only.
There are currently two petrol engines fitted that I know of, a straight six
and a V8. There are also three diesels, an old indirect injection naturally
aspirated 4.2, an electronically controlled 24 valve turbo/intercooled
4.2direct injection and a 12 valve mechanical direct injection version.
Huw
M
Guest
I had a 1949 but it did not have a locking differential
mike hunt
J
Guest
Discussion Starter #6
"Huw" <hedydd[nospam]@tiscali.co.uk> wrote in message
> This is with rigid axles all round. It could also have a semi floating or
> a full floating rear axle type.
You mean the Land Cruiser gets an electric locker, like what they put in the
TRD Tacomas?
H
Guest
Discussion Starter #7
>>> 4 Wheel Drive. The difference being that all wheel drive can be
>>> left on -- or is on -- all of the time, and 4WD can only be used on
>>> dirt or snow and ice -- surfaces where traction is "compromised"
>>> and the tires can slip and slide to release the stress of going
>> actuated mechanical diff lock on the rear and a similar diff lock on
>> the front. This is with rigid axles all round. It could also have a
>> semi floating or a full floating rear axle type.
> in the TRD Tacomas?
Since I do not know what they put in TRD Tacoma I cannot answer your
question. The original poster and I can confirm the availability of both
front and rear differential locks which have electric motor actuation on
Land Cruisers.
Huw
J
Guest
Discussion Starter #8
>> in the TRD Tacomas?
> Land Cruisers.
Forgive my ignorance. The only Land Cruiser I know of that isn't from the
'70s, and only has a locking Center Differential Button. It does not lock
the axles, either of them.
R
Guest
Discussion Starter #9
"Jeff Strickland" <[email protected]> wrote in message
>>> in the TRD Tacomas?
>> Land Cruisers.
Land Cruisers were definitely available in the U.S. with locking ceneter,
front, and rear differentials. Alas, I don't remember what years.
Ray O
H
Guest
Discussion Starter #10
> ceneter, front, and rear differentials. Alas, I don't remember what
> years.
It would be the 80 series and they were built from 1990 to early '98. Over
here in the UK they had three locking diffs fitted as standard for the whole
time. Other option choices were available in other geographical areas.
Huw
R
Guest
Discussion Starter #11
>> years.
> Over Yup, thos
> whole time. Other option choices were available in other geographical
> areas.
> Huw
Yup, those are the ones. I remember now that the locking diffs were
standard here in the U.S. as well.
Ray O
J
Guest
Discussion Starter #12
>> years.
> Over here in the UK they had three locking diffs fitted as standard for
> the whole time. Other option choices were available in other geographical
> areas.
The Land Cruiser that I know of is from this range, and it only has a
locking Center Diff. I know it only has the locking center diff because I
helped him get unstuck one day, and he had diagonal tires spinning uselessly
while he was high centered on a pile of dirt.
H
Guest
Discussion Starter #13
>>> years.
>> for the whole time. Other option choices were available in other
>> geographical areas.
> because I helped him get unstuck one day, and he had diagonal tires
> spinning uselessly while he was high centered on a pile of dirt.
They have to be engaged by the driver ;-) The centre diff may be engaged by
a button and the rear and then front on a rotary dial down by the drivers
knee. The axle diffs also take a while to engage and lock in my experience
and if not regularly used may not work at all.
Huw
J
Guest
Discussion Starter #14
in article [email protected], Huw at
hedydd[nospam]@tiscali.co.uk wrote on 1/26/06 2:17 AM:
>>>> years.
>>> geographical areas.
Most of the 80-series cruisers from the mid-90's don't have the locking
front and rear differentials. I know because I really wanted them, and
never could find one with them anyone near to me! And there were many, many
of them for sale. Since then I've seen a couple for sale; they do exist,
but they are the exception to the rule.
I haven't pushed my '95 hard, but what wheeling I've done it did great. Hit
some mining roads in SE Oregon that would have eaten an Explorer for lunch.
-jeff
J
Guest
Discussion Starter #15
>>>> years.
>>> geographical areas.
> by
Yes, but if the driver points out the Center Diff Lock button to me, and
uses it, then it is safe to say that the diffs did not lock. I have Detroit
Lockers on my Jeep precisely to cure the problem this guy had -- spinning
diagonal tires.
J
Guest
Discussion Starter #16
in article [email protected], Jeff Strickland at
[email protected] wrote on 1/29/06 6:51 PM:
>>>>> years.
>>>> geographical areas.
>> by
> diagonal tires.
Putting an 80-series land cruiser, ANY of them, in 4-low locks the CENTER
differential (IE, the transfer case). It's viscous-coupled in 4-hi,
mechanically locked in 4-lo.
Aside from that, a small minority of Land Cruisers have electric front and
rear locking differentials, similar to an Electrac, made by the same company
that makes your Detroit locker. The Cruiser you pulled out obviously didn't
have the front and rear lockers. They all have the locking center
differential though.
Make sense?
-jeff
H
Guest
Discussion Starter #17
>>>>>> what years.
>>>>> '98. Over here in the UK they had three locking diffs fitted as
>>>>> standard for the whole time. Other option choices were available
>>>> has a locking Center Diff. I know it only has the locking center
>>>> diff because I helped him get unstuck one day, and he had diagonal
>>>> tires spinning uselessly while he was high centered on a pile of
>>>> dirt.
>>> engaged by
>>> drivers knee. The axle diffs also take a while to engage and lock
>>> in my experience and if not regularly used may not work at all.
>> and uses it, then it is safe to say that the diffs did not lock. I
>> have Detroit Lockers on my Jeep precisely to cure the problem this
>> guy had -- spinning diagonal tires.
> CENTER differential (IE, the transfer case). It's viscous-coupled in
> 4-hi, mechanically locked in 4-lo.
> front and rear locking differentials, similar to an Electrac, made by
> the same company that makes your Detroit locker. The Cruiser you
> pulled out obviously didn't have the front and rear lockers. They
> all have the locking center differential though.
> Make sense?
They don't have a centre diff [or therefore a centre diff lock] in all
market regions. In some places they had part time four wheel drive and only
drive the rear wheels unless 4x4 was selected. These may or may not be
fitted with front free wheel hubs.
There are many more optional configurations than most people realise and
some may not be available in all regions.
Huw
1 - 17 of 17 Posts
