No I am not after a drop. I have an SE and want to retain the same height but get a little softer ride. So I was thinking of the LE/XLE struts but with the SE springs in them might do the trick. Anyone tried this? I dont think I want the LE/XLE struts and springs both as I heard those are extremely soft. Somewhere in the middle I suppose...
Okay so the
SE springs are a tad bit lower than LE, I think .25 or .5 inch.
not to mention the SE kit lowers provides a "lowered" look.
I don't think there's a model inbetween SE and LE/XLE, so you're stuck with those 2 choices.
The SE springs are a LITTLE firmer. Very little, difference is almost unnoticeable, as they are also lowered a little. The SE strut however was valved differently from the LEs, I think a 10%~ stiffer than LE struts.
Your best bet to retain the same height but even more comfort is probably to swap out your
struts with struts from an LE or XLE. But the cost will be in the couple hundreds.
You'd have to buy LE struts from Toyota since only they valve the struts the struts differently,
any new strut assembly you buy is going to be stiffer than it is now.
Actually I think the more wear you put on your struts, the softer it gets as it deteriorates :lol:
someone double check that for me though.
The tires do make a big difference in ride comfort. You can try that first if you are due for new tires. If not, your idea of swapping LE/XLE struts will absolutely work.
Its funny to hear people gripe about how harsh the SE suspension is, and here I am complaining how it's as soft as shiet!
Yes, try getting some softer tires (lower treadwear rating)
Good luck finding someone to swap with you though.
Yeah that's the first time someone complained about how harsh it is.
My gf notices a different between her 08 Honda Accord and her moms Lexus 2006 ES but
to me, her Honda drives like a boat, I can't imagine the difference between stock suspensions lol, they all feel good to me.
