1 - 4 of 4 Posts
My camry is leaking engine coolant from the engine. Not from the radiator or any of the hoses, but from the engine. Its a 3SFE and i was wondering if somebody knew what it could be? If any of you are familiar with this, or have had this happen to them, its leaking from an area right under the alternator. I called up my mechanic and he said it's probably the water pump but i wanted to get another opinion on here. thanks guys
Know God. Work Hard.
4Runner
Do you hear a "Boiling Water" noise when your car is on? It should be audible more inside the car than outside. If yes then its DEFFINETLY the water pump.
1 - 4 of 4 Posts
