When I removed the passenger seat to get at my engine I found oil staining all around the PCV valve. Is the PCV valve supposed to be tight tight in the grommet... i.e not able to wiggle it around? I was able to pull the PCV valve out the grommet without any real effort. I ordered a new valve but forgot the grommet... whoops. Have others of you seen oil staining around the PCV valve like this? I'll check my PCV return line tomorrow for flow. My engine is running a little lean these days (LTFT @ +10-15). I'm wondering if this little grommet is the source of a vacuum leak. Oil+air flows out when crankcase pressures up, but leaks air in causing a lean condition when crankcase pressure is low??? Unfortunately I'll have to wait for a week (and pay $8 in shipping) for a $4 grommet to test my theory.
I noticed that Cmh1129 had a photo of the same staining in his very helpful Valve Cover Gasket post.
