1 - 5 of 5 Posts
is it normal to have oil leaking into the rotor cap from the distributor?
i don't know why it's doin' that....argghhh. it leaks into the cap...just a small amount, but then it leaks out of the cap and drips all over the hoses and such, then down the tranny.
has anyone experienced this?
also, there is a small opening on the bottom of the distributor casting. is there suppose to be a hose hooked up or what? could this be what's causing the leak?
someone from MR2OC.com said that the internal seal is bad. sounds good, but i want some confirmation on this. thanks.
1 - 5 of 5 Posts
