1 - 9 of 9 Posts
If I have a cat, can I leave the AC on and lock the doors. Will someone be able to break the window and drive off?
Yes. As you will have to leave engine running. And the thing about those cars is - you step out with engine running, someone else can get in and drive car away until it runs out of gas.
That's the reality. Unless thye changed it for the late models. But I am not the only one who noticed that and actually even left system on few times.
I googled and found a reddit response. Replier claimed:
(1) leave engine on (2) lock door from inside (3) open door with handle (4) close door and lock with metal key.
This would lock the car with it running. But if someone broke the window, he could drive til the gas runs out or to the next destination.
It would not be obvious that the car is on until the engine restarts to charge the batteries, or someone at night sees dash lights. I could dim the dash lights.
I could put a gps tracker to retrieve a stolen car.
With the AC on it would be obvious that the car is still running even with the engine off as the AC compressor/fan are still making noise.
TableRocked
A cat uses your vehicle as its litterbox and the value of your highlander drops by 50% or more..... :)
I'd put the cat in a cage on the roof.
Wait! If the thief is smart enough, he/she will keep the engine running and just keep adding more gas with stolen money and travel the country with your cat as his/her companion... after the trip, respond to your return cat reward money (ditch your stopped/out of gas car) and move on to the next running vehicle with AC on... Woohoo!
2019 Highlander Hybrid XLE
Yes, if they break into the vehicle they can drive it off until they turn off the system at which point they're stuck.
Bob Peloquin - 2019 Highlander Hybrid XLE
1 - 9 of 9 Posts
