1 - 9 of 9 Posts
i m wonderin, is it possible to replace led lights on the sun visor, i m plannin to replace all the interior lights with led, if i cant change the lights on the sun visor, it would make my car look weird
2009 Venza AWD
I have a list of LED replacement lights for most of the interior lamps. I can send it to you if you want, but keep in mind that I have not thoroughly looked into which one is right (for brightness) yet.
Yes I have done it myself. All interiors are LEDs except for glove box light. Here is a list and instructions you'll need.
http://www.toyotanation.com/forum/showthread.php?t=299364
They're parts for Camrys but they fit fine with Venzas
thnx alot great link, but i cant see how to remove the sun visor light cover...is it hard to remove
It's the SAME method you use to pry off the other light covers. Get a really small/thin flathead then cover it with a thin cloth (if not Toyota's hard plastics will get scrapped) and find a corner and pry. Once you've done one the rest is the same EXCEPT the rear reading lights and the glove box light. Don't overthink it, it's easy
Discussion Starter · #6 ·
the hardest part is the license plate lights....need to remove the cover holy!!!! but r u able to tell me how many bulbs i need for the plate lights? is it just 1? or two like regular cars?
Discussion Starter · #7 ·
hey guys, i tried to remove the sun visor light covers....i couldnt get it remove....how to remove it ??? plz tell me!!!
Sun visor lights
I was looking into replacing these also. I find this hard to believe but according to the service manual you need to get at them from behind. Step one - remove the headliner!!!!!:confused:
Thin flathead + cloth. Pry from one side and it will come off. It's very easy don't remove headliner.
1 - 9 of 9 Posts
