Okay a bunch of people have been asking for pics n' stuff, but I figured it would just be easier to take a short video. So here it is...
http://www.youtube.com/watch?v=vScymscuyKg
The LED's were ordered from www.superbrightleds.com and below was my invoice incase any of you would like to get exactly what I put in the car.
PRODUCT INFORMATION--
Quantity: 2
Product: 3157-xLX3 Luxeon LED bulb $ 24.95 (each)
Options: Amber 3157-ALX3
(Used as front blinkers/parking lights)*see note below
Quantity: 2
Product: 3156-xLX3 Luxeon LED bulb $ 23.95 (each)
Options: Amber 3156-ALX3
(Used as rear blinkers)
Quantity: 2
Product: 7443-xLX3 Luxeon LED bulb $ 24.95 (each)
Options: Red 7443-RLX3
(Used as outer main taillights)
Quantity: 1
Product: LED bulb Flasher Unit $ 12.95 (each)
Options: CF18-08
(Replaces stock flasher unit located directly behind the gauge cluster)**see note below
Quantity: 5
Product: WLED-WHP Pure White High Power $ 4.95 (each)
Options:
(1 used for front dome light
2 used in front reading lights
2 used in backup lights)***see note below
Quantity: 1
Product: WLED-x5 LED Wide Angle LED bulb $ 2.99 (each)
Options: Cool White WLED-CW5 0.95
(1 used for trunk light)
Quantity: 4
Product: WLED-WHP6 6-LED bulb $ 4.95 (each)
Options: Cool White - 8500K
(2 used for door courtesy lights
2 used for license plate lights)
Quantity: 2
Options: Red WLED-R5
(used for the trunkside taillights)
*Note for the 3157-xLX3 Luxeon LED bulb's: You must purchase a 6ohm resistor for the parking (lower intensity circut) or else it will blow your "TAIL" fuze under the dash. That resistor is not listed above because I have it on order right now.
**Note for the LED bulb Flasher Unit: You must install this if you have LED flashers to prevent hyperflashing. This requires temporarily removing the gauge cluster.
***Note for the WLED-WHP Pure White High Power: I will need to purchase 2 more of these to put in my rear seat reading lamps, I just haven't figured out how to get the originals out yet. So if you're ordering, and plan on installing rear LED reading lamps, then get 2 extra of these.
Remember that most LED's are polarized and can only be installed in one direction in order to work correctly. If you install an LED and it doesn't work, take it out and install it the other way. Positive must be connected to positive and negative must be connected to negative.
It was a fun intall. Hope this helps somebody.
Quantity: 2
Quantity: 2
Quantity: 2
Quantity: 1
Options: CF18-08
Quantity: 5
Options:
Quantity: 1
Quantity: 4
Quantity: 2
