1 - 20 of 26 Posts
I've had my corolla for about 6 years now and have only had to put 2 sets of pads on it in that time. Recently, I purchased a set of Raybestos (Element 3) Hybrid brake pads. What makes them interesting is that they are a hybrid of both semi-metallic and ceramic brake material, according to the website. They are supposed to offer benefits of each. I've never seen these before, and I've like Raybestos pads in the past for daily drivers, so I decided to buy a pair and see what happened. What a piece of garbage they turned out to be.
They started off great. Quiet, smooth, good stopping distance, but as time went on, I started to notice more of a "squeal" as I hit the brakes. I do a lot of highway driving so sometimes you're on the brakes for a good distance. Just the other day, I rode the brake down an entire block and they squeeled the whole way. Coincidently, the more noise, the worse the braking has become. The rotors are clean and true. I changed them when I bought the pads and they don't vibrate and are very clean.
So what about you? Are there and pads that you found to be so bad that you couldn't wait even half the life span before a change? Or what about some pads that you bought and they turned out to be absolutely wonderful? Let me know you're story, and if you're curious, here's a link to the Element 3's from above....
https://www.brakepartsinc.com/raybestos/products/friction/element3-pads.html
Super Moderator
2006 Corolla XRS
Did you replace the pads? Check the guide pins and the piston. If the caliper is applying uneven pressure, means that one pad is touching the rotor surface or is too close to the rotor face. The squeals as pressure is applied.
This is my gripe with ceramics. They rub or make noises. This MY experience with them after several Toyota vehicles. Every time I replaced them with semi mets, problem was gone.
Now, here's just an observation. Hybrid anything is a spork - neither fork nor a spoon. Neither great semi met nor great ceramic.
As to your concern, OP. I safely bet you have glazed rotors. And they WILL squeal. Look at them. Are they SHINY? If they are, there it is. Kinda like a mirror.
Hard pads (ceramic) develop that glazed layer and then it acts like a chalk board type noise producer.
I had quite a few rotors that did this after hard pads install or, simply from age. That layer needs to be removed, either by turning or taking high speed grinder wheel to it and shaving it off in circular motion, aka Blanchard grinding.
Best way to proceed with brakes is to have new/resurfaced rotors bedded immediately with new pads. that creates cementite layer in rotor that is very resilient to any wear and glazing and it all lasts for years.
The Return of the Red Coupe
16 Scion tC
I actually replaced the Toyota OEM Metallic pads on my RAV4 with the Z17 as well because the OEM were squealing to shite when reversing... no squealing now with the full Ceramic.
I always buy cheapest pads, I don't know difference. If they make noise, there is special glue (?) for that.
Last couple times I got brake pads from junk yard. I don't go there to get pads, I go for something else, why not to grab brake pads for free?
Senior TN Member
Porsche
I prefer performance semi-metallic pads, they don't ever squeal. Such as Hawk Performance or EBC Orangestuff.
イリジウム
Check out Akebono Proact ceramics on rockauto. Google up a 5% off code.
Centric rotors if you need them. C-tek doesn’t have coated hubs, their Premiums do.
イリジウム
Check out the pads on rockauto, plenty of low cost alternatives like Centric C-Tek series, but I recommend Akebono.
JIS K2228 approved grease like CRC Silaramic grease if needed. Permatex green or purple will swell the rubber and cause things to stick.
Last couple times I got brake pads from junk yard. I don't go there to get pads, I go for something else, why not to grab brake pads for close to nothing?
I got the centrics from RA, fit and seem fine, didn't touch the rotors, they did not need it. I think it was $17 to my door for the Echo. They scuffed the edges and shut up in a few miles. I seldom use the brakes, coast more, or be less aggressive but the lights need to be green when I get there and some Morons don't understand the conservation of inertia.
Senior TN Member
Porsche
Yeah, I can go from home to work and touch brakes maybe 5-10 times.
I have co-worker who needs to replace his pads every other month.
Any chance he gets, he stabs brakes.
Someone brakes 2-miles up freeway, stabs brakes.
Someone ahead changes lanes, stabs brakes.
Wants to change lanes? Stabs brakes.
Official PITA
Solara 'Vert & ES350
I just put those Element3 pads on my car. So far, so good, though there seems to be a lot more brake dust on the wheels. The difference between cheap & expensive pads is the coefficient of friction (CF), or how grabby the pads are. The Element3 pads are rated GG, while most low cost ceramics are FE.
Have a look here for detail on pad CF ratings: http://faculty.ccbcmd.edu/~smacadof/DOTPadCodes.htm
BTW -- " Also, you should know that Steel on Steel has a C.F. of 0.25!! So EE pads have only marginally more torque than no pads at all" ...and FE pads when hot, really really suck.
I've never had squeal from my brakes, but I always us a sticky spray (Permatex) on the back of the pads, and the anti-rattle shims, and the silicone grease. A little of a PITA to get it right, but it pays off.
Various Toyotas
My preference is for Advics pads. It's parent company is Aisin, which is 30% owned by Toyota.
Close 2nd preference is Akebono.
I just put element 3 pads on my car. So far, so good, though there seems to be a lot more brake dust on the wheels. The difference between cheap & expensive pads is the coefficient of friction, or how grabby the pads are. The Element3 pads are rated GG, while most low cost ceramics are FE.
Have a look here for detail: http://faculty.ccbcmd.edu/~smacadof/DOTPadCodes.htm
I've never had squeal from my brakes, but I always us a sticky spray on the back of the pads, and the anti-rattle shims, and the silicone grease. A little of a PITA to get it right, but it pays off.
Force on pedal is multiplied by brake booster, so if you have cheap brake pads you will have to depress pedal about 1/4 lb. harder!:smile:
Official PITA
(Smacks self upside head) You're absolutely right !!
But, I'm confusicated
Riddle me this:
Why they make all kind brake pads?
Why not use only Solid Steel Pads?
Like you say: Just Press Harder.
"Yeah.... That's the ticket! Solid Steel.
"Me brake pads are SS pads. Solid Steel.
"Strongest, brightest, longest lasting pads in dah world.
Various Toyotas
Riddle me this:
"Confusicated". I love that! I'm going to add that to my lexicon and start using that "word" too! Thanks!
If there were solid steel pads, the rotors would have to be replaced every week, so that wouldn't be practical.
I hate OE pads and have replaced most when about 1/3rd worn.
No squeal from my OEX, ASP, Green, Yellow, Red, Black, Carbon-semi-metallics, TQ, Z23, or EHT pads. Doing the job right prevents issues regardless of how cheap or fancy your pads are.
Force on pedal is useless if pads fade or cook to dust from heat.
CF isn't the difference among pad cost. Performance of the pad material is what counts regardless of the CF.
Senior TN Member
Porsche
Yup, and doing job right requires lubing caliper pins with proper grease. You cannot use generic oil-based greases, which breaks down rubber seals. That is low-temp stuff and causes the pins to seize even if rubber seals haven't been compromised yet.
Needs to be high-temp silicone grease. You can tell it's proper lube because when you go to replace pads again, the pins will still be sliding smoothly. So no imbalance between inside & outside and no squealing during entire lifetime of pads.
[ame]https://www.amazon.com/dp/B001E6WB9M/[/ame]
Various Toyotas
1 - 20 of 26 Posts
