1 - 4 of 4 Posts
1992 Toyota Pick Up
I don't see the wheels selling, so email the seller and ask for some specs. Make sure your bolt pattern is that of those listed, also ask for center bore. Center bore seems like such a big thing these days. :rolleyes:
I don't see backspacing and offset to make much difference on your truck, but ask the seller for specs, and compare them to wheels other 4wd guys are running here!
94' 2WD Pickup
These should fit, the bolt pattern is the same, as far as the back spacing goes you may want to consult some of the other forums for that, or I am sure Sidney would be able to inform you. I have seen early 90's Toyota 4X4 pickups with late model Toyota 4X4 alloy's on them. for the price it would be worth it.
1 - 4 of 4 Posts
