1 - 17 of 17 Posts
· just a nobody
Echo
Did you meant to say "oil smoke"?
Never seen an engine smokes oil before, video please! 🤣🤣
Check the valve cover bolts, make sure they are nice and tight. If they are tight, then you might consider replacing the gasket; otherwise, clean off the oil and keep an eye on it.
Discussion Starter · #3 ·
Lol brain and fingers weren’t working right. Engine compartment was smoking on startup.
No questions about it, vcg is being replaced.
I just started on it an hour ago. I think I need more stuff done to if. 2 new boots for the steering links/arms, possibly a new radiator (doesn’t need one yet but it’s getting there.)
Discussion Starter · #5 ·
Ended up ordering a denso radiator, felpro vcg, moog steering boots off of amazon. I did not like what advance or autozone had. I was going to order thorough rock auto but prime makes returns a breeze (big hunking radiator) so I stuck that route.
Sprayed the piss underneath the compressor and behind the block/steering pump. Removed a ton of build up. It was pretty gross. I’m going to brush the piss around the the front vcg tomorrow b/c that’s all I can do till the boots show up later afternoon. The rest be delivered on Wednesday but can’t finish till Saturday.
I’m being lazy and will save the rear vcg for a later date .
Discussion Starter · #12 ·
It’s a motor out kinda job - no way around it messing with the chains and cams. to think I saved the rear vcg for later - the back isn’t messed up I’m guessing and hoping. I’m roll with it b/c I’m adventurous. We’ll see. I’ll update if the motor blows up.
· just a nobody
Echo
Maybe you can tighten the gear back down, give that a try. Still would be a good idea to replace the gear for long term, but at least you won't have to worry about the gear coming off until you can get that done!
Oops, I was looking up something else! Here you go; not the best quality but it will give you some idea:
Discussion Starter · #16 · (Edited)
There is no way to tighten it - no room. 3/8” max. Wish I could. Edit, there’s room after I move it over. The cam does not wobble- has absolutely no movement when I loosen the cam with a wrench. Which confuses me on why the hell that part is loosened. I suspect it broken off some where.
In the video, They are able to do that b/c the cylinders are on the driver and passenger side. Mines facing front and rear. Front wheel drive. It’s an engine out fix. thx for that video, it was a really good video.
1 - 17 of 17 Posts
